Brake trouble
Brake trouble
I need help with my brakes!
On the way home from work I had two incedents where when I pressed the brake pedal down and the pedal felt weird and almost went down to the floor with little resistance with the car not really stopping.
Any suggestions as to what it may be?
Re: Brake trouble (blueeg)
It's either a leak in the lines somewhere (not likely as it would happen constantly)...
Or what I think... a bad master...
Even if you don't see a leak it could be bad as usually it's an internal leak where the fluid leaks past an internal seal back to the resivour...
good luck..
good luck..
Re: Brake trouble (POS Hatchback)
you have to switch the master and booster in but yes... it will...
depending on your year and what master is in there it may require some line bending...
I have a 93 ex coupe with a 7/8ths stock and a 90-00 integra rs NO abs 15/16ths bolted RIGHT up... no line bending.. but like I said had to swap the booster too.
Good luck.
Good luck.
Re: Brake trouble (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz »</TD></TR><TR><TD CLASS="quote">
I have a 94 Si with ABS
The donor car is a 01 ITR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POS Hatchback »</TD></TR><TR><TD CLASS="quote">
The donor car is a 01 ITR</TD></TR></TABLE>
I don't know specifics... If you look at it it should be obvious whether you'll have to bend or not.
as far as I know NO master will swap in w/o the booster too.. and ANY master/booster combo of ANY integra civic will fit...
cool,
I just ordered the integra MC, booster and proporting valve.
Im also going to toss on some new brake lines while Im at it. Any reccomendations?
be patient and do some situps or get a heated blanket cuz your back is gunna HURT after sitting upsidown getting the 4 booster bolts off and the new ones back on...
OH actually... take out the driver seat... it makes it MUCH MUCH easier to get under the dash... I was going to do it on day one but decided no too... did it on day 2 and it sped things up considerably.
Im also going to toss on some new brake lines while Im at it. Any reccomendations?</TD></TR></TABLE>
bump
bump
Specail Ed
03-31-2008 08:25 AM
dxhatch92
01-16-2007 08:13 PM
DRKSol
09-14-2004 09:04 AM
