can someone tell me how to bleed slave cylinder? a short how-to?
Re: can someone tell me how to bleed slave cylinder? a short how-to? (nortel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nortel »</TD></TR><TR><TD CLASS="quote">that helped </TD></TR></TABLE>
here , I'll hold your hand this time , ready?
get extra brake fluid
open cap
find 10mm wrench
attach bleeding hose to slave cylinder
pump clutch
hold clutch
open bleeder
close bleeder
repeat
add more fluid as needed
stop when you have a nice pedal feel.
open cap
find 10mm wrench
pump clutch
hold clutch
open bleeder
close bleeder
repeat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nortel »</TD></TR><TR><TD CLASS="quote">its 8mm *******</TD></TR></TABLE>
yeah , you win...
yeah , you win...
Re: can someone tell me how to bleed slave cylinder? a short how-to? (Doctor CorteZ)
Want help?
Search for it...it's been covered.
But anyways, the slave cylinder has a one way check valve.
Open the 8mm on the slave, pump pedal two to three times slowly,
add fluid in resivoir. Repeat. No need to open and close the 8mm like brakes.
This is from the Helms manual.
New User
Re: can someone tell me how to bleed slave cylinder? a short how-to? (2 B 4GO10)
1. Make sure resivior is full
2. Pump clutch, slowly, wait 2 seconds after every pump. Do 4-8 times. Hold clutch pedal as hard as you can.
3. Have friend (whomever) open bleed screw on slave cylinder (8mm) until all the fluid comes out.
4. Close bleed screw
5. Release pressure from clutch pedal
6. Repeat, as many times as you want, to get clean fluid and all air bubbles removed.
perfect... hopefully you can follow that. Its fairly self explainatory
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ »</TD></TR><TR><TD CLASS="quote">
open cap
find 10mm wrench
pump clutch
hold clutch
open bleeder
close bleeder
repeat
open cap
find 10mm wrench
pump clutch
hold clutch
open bleeder
close bleeder
repeat
According to the Helms, bleeding the clutch is nothing like bleeding the brakes.
1. Put a hose on the bleeder at the slave cylnder. put end of hose in an empty bottle.
2.Crack open bleeder.
3. Uncap clutch resiviour, make sure it is full.
4. Slowly pump and pull the clutch pedal with your hand. This will pump fluid through sytsem.
5. Keep an eye on the resiviour, dont let it go below the empty line. You should need to add fluid every 5 to 8 pump strokes.
6. Keep pumping and filling till you see no air come out of the hose on the bleeder.
7. Close bleeder.
8. Test clutch pedal.
7. Close bleeder.
