Window out of track
Window out of track
Hello all,
minor prob i cant seem to get my driver side window all the way up! i took off the door panels and it is out on both rubber runners! the motor works fine but it wont go all the way up! i cant seem to squeeze in back into the runners! any ideas its a 96 ex power windows! mayb im just a retard but hey!
Re: Window out of track (Bamex)
that happened to me a few times im not sure if its the same prob tho.. basically the bolt holding the window got loose. im a noob and the terms im using mite be wrong but u may want to take out the 6'' speaker and behind it you will find where the track hooks up to the window. try realligning it and tightening the bolts... hope that helps
Re: Window out of track (92civeg)
ok fixed the track problem but now the window is kinda sluggish! motor kinda goes and then slows down going up and down! bad motor?
Re: Window out of track (jspexae102)
use sum silicone spray in the rubber tracks or sum white lithium grease.. my rubber track unforunately got all messed up because my cousin forced it up all the way off the rubber track. I just ordered a new one but dont know if it is hard to change. Anyone done this before?
btole
09-13-2004 08:01 PM
