bolt and washer trick?
im gonna do the bolt and washer kit to fix my camber in the rear. i was wondering if any one took pics so i would know exactly which bolt i had to replace and where i would have to put the washers. tia!
TSPeed Factory
Re: bolt and washer trick? (silverEH2)
depends how negative your camber is. for me with a 3" drop i used 3-4 washers per bolt. theres no real way to tell how perfect it is besides eyeballing it.
buy a bunch of washers and test it out. I used a 3 washers per bolt for a 2.5 inch drop. Also i didn't have to replace the bolt. Just use the stock bolts and add washers.
Re: bolt and washer trick? (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">theres no real way to tell how perfect it is besides eyeballing it.</TD></TR></TABLE>
true. you can also place a leveler against the wheel, but again it's still pretty much eye balling.
benitom
Suspension & Brakes
16
10-14-2008 04:46 AM
blackdc5
Welding / Fabrication
13
05-09-2006 11:21 PM
A.E Motoring
01-05-2006 08:42 PM
