4 wire o2 Wire colors: Go out to your car and check please!!
The harness I have is really weird. THe colors on the sensor on the wire harness side are this:
1. Yellow with black stripe
2. Orange with black stripe
3. White with black stripe
4. Green with white stripe.
Where do I put the wires? I have a 1 white 1 green and 2 black ones!
THis is my last step to see if my car runs right!! HELP!
It's a stock 02 sensor.
Not aftermarket. Im just trying to get it plugged up now that I have a z6 wiring harness for my CX.
The thing is we took off the connector to bootleg the 4 wire o2 and since it didnt work.. I said screw it and I picked up the z6 one. The cap is off.. and I dunno where the heck the pins go for this one.
THe wires are complete different colors on both sides.
Yeah man. Where are all the tech people? This is something simple but like always.. even in the threads searched for.. there aren't enough detailed posts to say which goes where.
THe wire harness side has an orange/black wire, a green/white one, a white/green one, and a yellow/black one.
While the stock 02 has 1 white 1 green and 2 black. Wtf? Where do they go!!!
Wow so can you please tell me which wires go where??????
If yours is connected.. that's what I need man. I need to know which wires are connected through the harness to which other wire.
Here's a reference to go off of. Because I don't have my harness clip...
Make the clip part face upwards.. where you press to unclip it.. and match the wires for me. TEll me where hte o2 wires which one it lines up with.
SAINT.. OMFG
Okay so let me get this right..
WIth the tap up facing me..
Plug the green one into the top left.
Plug the white one into the top right
Plug which black one into which one? I thoughti f you mix those up it wont work.
CEL is throwing a 41. Heater Circuit o2 malfunction.
wht with wht
grn/wht with grn
orn/blk with blk
yel/blk with blk
engine sensor
the 2 blk wires from the sensor yougot to flip the coin on that if it wrong flip it around.
grn/wht with grn
orn/blk with blk
yel/blk with blk
engine sensor
Nah through the o2 plug on the z6 harness. Im plugging the pins into that.
It's still throwing a 41.. Either way I pin up the black ones. Which C-speedracing says 41 is o2 sensor - Heater Circuit Malfunction.
do this get multimeter and meter out the o2.
set the meter to ohm setting, and with sensor plug tap face up ohm out the 2 bottom wire you should get 10-40 ohms. if no then replace the o2 if yes then few more things to check.
i know what it is..
I have to directly wire into the ECU. CX - 1 wire o2. It's not prewired to accept a 4 wire like other cars. son of a bitch.. GAWD I just spent 80 on a damned z6 harness for NO reason. GJDKLJDKLFJDLFDS Going to wire will update.
