tranny wont go into reverse
my car wont go into reverse what should i do buy a new itr tranny or rebuild my b16 tranny, what causes this problem and how much do itr tranny run for.
Re: tranny wont go into reverse (B16SI00)
id rebuild your tranny, for the money u will spend on an itr tranny it wont be worth it. plus you already have the same gearing pretty much
reverse is the only one you're having problems with? It's probably a synchro or the proportioning gear or something along those lines. Reverse always seems to be a little finiky on Hondas, so you're sure it's dead? And you don't have to get an ITR tranny for those gear ratios... look around and I'm sure you'll find one (maybe even w/ a lsd) with similar/ better ratios than the ITR.
Solbros Owns Me
Re: tranny wont go into reverse (FrostySol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrostySol »</TD></TR><TR><TD CLASS="quote">reverse is the only one you're having problems with? It's probably a synchro or the proportioning gear or something along those lines. Reverse always seems to be a little finiky on Hondas, so you're sure it's dead? And you don't have to get an ITR tranny for those gear ratios... look around and I'm sure you'll find one (maybe even w/ a lsd) with similar/ better ratios than the ITR.</TD></TR></TABLE>
reverse doesn't have a synchro...it's a straight cut gear off on it's own.....the reverse idler arm could have gotten bent possibly.
Re: tranny wont go into reverse (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">
reverse doesn't have a synchro...it's a straight cut gear off on it's own.....the reverse idler arm could have gotten bent possibly. </TD></TR></TABLE>
^yeah that's what I meant! sorry, it was early and I was in class
Re: (MichaelJComputer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MichaelJComputer »</TD></TR><TR><TD CLASS="quote">be sure to put it in a forward gear before trying reverse, that may solve the problem.</TD></TR></TABLE>
i will sometimes have a problem puttin my car in reverse, so i take it out of reverse and put it in 5th then back into reerese and it goes right in... just works for me, try it
Re: (Vtecin94dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecin94dx »</TD></TR><TR><TD CLASS="quote">i will sometimes have a problem puttin my car in reverse, so i take it out of reverse and put it in 5th then back into reerese and it goes right in... just works for me, try it</TD></TR></TABLE>
This is because there is a lock on reverse so that way when your going down the highway, you don't accidently throw your car into reverse thinking the car is a six speed.
If you go in first, let up on the clutch, put the clutch back in, if it's a normal tranny, it should slide right in.
Re: (asmallsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asmallsol »</TD></TR><TR><TD CLASS="quote">
If you go in first, let up on the clutch, put the clutch back in, if it's a normal tranny, it should slide right in. </TD></TR></TABLE>
yeah thats what im talkin about, thanx
Sometimes with my old EX it wouldn't let me in until I let out the clutch more or until I put it into first before.
Try some of these before you waste money on a newer transmission.
my tranny has been work on before when i got my synchro's replace at a honda delership. thanks for all your help i will try all of those things when i get of work
Re: (B16SI00)
I had the same problem. Does your tranny grind any gears when you shift normal?
I had a broken shift fork stuck into the reverse gear. I thought my syncros were crap when in fact my shift fork were broken. Took tranny apart pulled out the crzap and booooom!! Hooked it up!!
bhatchracing.com
bhatchracing.com
Could be something simple...check your fluids, I know mine was low last week and it wouldn't go in any of the gears...pumped the old tranny fluid out and put some new fluid in...runs great now.
Worth a shot...may as well check it out.
Re: (Infamous_Imports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Infamous_Imports »</TD></TR><TR><TD CLASS="quote">Could be something simple</TD></TR></TABLE>
This should be h-t's motto or something! If people would just look at the easy stuff first there'd be a whole lot less expensive problems running around and people would figure stuff out way faster!
Re: (FrostySol)
and we are a bunch of poor people and sometimes stoopid. AS replaced my alternator twice in 3 months costing me 800 dollars when actually there's just some short circuit ($1.) and blown fuse ($3.) . damn mechanics (not all)..honda-tech is always a good place for second opinion. always do simple check first.
Black R
05-11-2003 07:53 AM
