Tab under code.
Old Mar 2, 2004 | 05:33 AM
monicle's Avatar
Default Tab under code.
Ok this tab is a problem to my turbo install. Im assuming its safe just to cut the damn thing off right?
Old Mar 2, 2004 | 06:31 AM
TurboBumblBee's Avatar
Default Re: Tab under code. (monicle)
yes you get a dremal and cut that bitoch off
Old Mar 2, 2004 | 06:39 AM
monicle's Avatar
Default Re: Tab under code. (hybrid94Si)
right on its as good as gone.
Old Mar 2, 2004 | 06:40 AM
blackhatchy's Avatar
kill it, kill it!
Old Mar 2, 2004 | 06:42 AM
Filliam H. Muffman's Avatar
Default Re: Tab under code. (blackhatchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhatchy &raquo;</TD></TR><TR><TD CLASS="quote">kill it, kill it!</TD></TR></TABLE>
pretty snail by the way.
Old Mar 2, 2004 | 07:43 AM
monicle's Avatar
Default Re: Tab under code. (JUN EK9)
heh thanks. My whole setup has been pieced together over the last year and its finally ready for install.
Old Mar 2, 2004 | 08:00 AM
xerox445's Avatar
oh damn, thats a rather large turbo Looks like its going to suck your slave cyl right in
Old Mar 2, 2004 | 08:35 AM
monicle's Avatar
Default Re: Tab under code. (xerox445)
hehe yeah Im working on that one too heh. Hopefully this will be my solution. http://www.taylor-race.com/pdf/HONDAHRS.pdf
I have a guy there checking if it will work with my exedy clutch.
Old Mar 2, 2004 | 09:17 AM
lohatch's Avatar
i would opt for a bigger tool than a dremel to get rid of that. AKA a grinder
Old Mar 2, 2004 | 09:25 AM
monicle's Avatar
Default Re: Tab under code. (lohatch)
yeah I have a grinder and a cutoff wheel attachment for it too if needs be. The dremme is nice and small though and easy to work with. Ill post pictures later today after I cut it off and check clearance.
Old Mar 2, 2004 | 09:27 AM
Kangaroo_Boy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">yeah I have a grinder and a cutoff wheel attachment for it too if needs be. The dremme is nice and small though and easy to work with. Ill post pictures later today after I cut it off and check clearance.</TD></TR></TABLE>
just use a reciprocating saw (aka sawsall)
b16 matt's Avatar
thats the funnest part of a turbo install, lopping chunks off of your block. Just dont be like the one dude who posted on here once, it read "I was grinding my block to fit my turbo on and some green liquid started comming out of it. what should I do?"
Old Mar 2, 2004 | 09:31 AM
monicle's Avatar
Default Re: Tab under code. (b16matt)
hehe yeah that would suck.
Old Mar 2, 2004 | 07:49 PM
monicle's Avatar
Ok I cut the tab but I have a feeling the stupid slave cylinder will be in the way. And those guys said that clutch release system only works on their clutches.
Declectic
Honda Civic (2006 - 2015)
Jul 22, 2006 11:23 PM
Boosteddc2gsr
Jul 1, 2005 07:21 PM
redlinetuning
Nov 4, 2004 06:27 AM
BobGnarly
Jun 27, 2004 07:41 AM
