cel, wtf!!!
cel, wtf!!!
yesterday i was driving my hb when i noticed the cel came on, the gas gauge was below empty. could having an empty tank cause the cel to come on? i put gas in it and it did not come back on. maybe just having low fuel pressure or something?
1 Post
Re: cel, wtf!!! (a1320honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda »</TD></TR><TR><TD CLASS="quote">ya, it was the cel, i have the bottom of the line dx that doesnt have a fuel light.</TD></TR></TABLE>
thats not the bottom of the line, but close enough
when and if it comes back on again, try and pull the code.
Re: cel, wtf!!! (blackhatchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhatchy »</TD></TR><TR><TD CLASS="quote">
when and if it comes back on again, try and pull the code.</TD></TR></TABLE>
actually, you still should be able to pull the code. the ecu stores the code even if the CEL goes off
1 Post
Re: cel, wtf!!! (97redex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97redex »</TD></TR><TR><TD CLASS="quote">
actually, you still should be able to pull the code. the ecu stores the code even if the CEL goes off </TD></TR></TABLE>
you learn something new everyday
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda »</TD></TR><TR><TD CLASS="quote">i tried pulling the code and nothing happened, the cel light stayed on</TD></TR></TABLE>
lol, what code did you pull?
Re: cel, wtf!!! (sickSOLvtec)
when i put the jumper wire in the clip, after the cel went off, the cel light stayed on, didnt blink or anything, just stayed on solid, what does that mean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda »</TD></TR><TR><TD CLASS="quote">when i put the jumper wire in the clip, after the cel went off, the cel light stayed on, didnt blink or anything, just stayed on solid, what does that mean?</TD></TR></TABLE>
Are you talking about the Check engine light, or the ECU light?
Ok so you turned your car off, put a paper clip or somethign similar in the service connector by your ECU and then turned the key to the on position and your check engine light is stayed solidly illuminated?
Re: cel, wtf!!! (Mr Milano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano »</TD></TR><TR><TD CLASS="quote">
Ok so you turned your car off, put a paper clip or somethign similar in the service connector by your ECU and then turned the key to the on position and your check engine light is stayed solidly illuminated?</TD></TR></TABLE>
This is what I thought also.
yes, i used a jumper in the 2 pin connector and the cel stayed on solid, it hasnt come back on and its been about a week, so i was just curious
Did you do it with the car running, or did you leave it turned off and put the key in the ON position without starting it?
If the former, do the latter. If the latter, ask someone else.
Jump the SVC Connector with the car totally off. Then turn to on position and see if still solid.
If still the same find someone with a PGM Tester. Unfortunately I'm a little out of your way.
Firestarter
10-06-2005 10:52 PM
