header problem
Old Sep 15, 2004 | 09:51 AM
92civic_si's Avatar
Default header problem
i hit a big bump n notice that my dohc 4-1 headers had a big dent on the bottom of them ..my car is picking up slow n i think the dent is blocking the air flow..do u guys think it's better to get a whole new header or can i just take the header to the shop n cut the dent out n weld a new pipe back on? would the weldding give the same performance?
thanks
Old Sep 15, 2004 | 10:37 AM
xhatchracerx's Avatar
Default Re: header problem (92civic_si)
buy a new header, but if you want to cut and weld it then it would be the same as long as the inner surface where the weld is, is smooth
Old Sep 15, 2004 | 11:28 AM
mikehawkBUiLT's Avatar
yea, make sure you have them sand the inner part if you get it welded cause god knows you'll lose 20 horses if you have little welds inside. very restrictive shiet.
Old Nov 23, 2004 | 12:55 PM
92civic_si's Avatar
Default Re: (EJcoupe1.6)
thanks for the tip!!
fitseries3
Feb 8, 2013 07:02 AM
gray_civic_coupe
Dec 1, 2005 05:12 AM
danxdan
Nov 1, 2005 01:30 PM
Jeff_B
Welding / Fabrication
Apr 23, 2005 06:50 AM
NVMYSi
Jul 13, 2003 06:58 PM
