Give me a hand on my GSR/EG (secondary butterflys)
Hi
Since I bought a car that was already swapped Im not to sure if my Secondary butterflys are opening.
I have:
94 VX
96 b18c1
Chipped (custom done by skunk) P28
Of course the P28 does not have any 2ndary Butterfly controls and Im not sure if steve @ skunk actually loaded the maps for them.
I ask because I can not hear them open, I remeber on my old GSR it was pretty clear (audible) when they opened. My VTEC is sure as hell kicking in, there is no problem there.
Whats a very easy way to trouble shoot this?
Cant I unplug the IAB plug and see if I get a check light up at the top somewhere?
Thanks much
I have:
94 VX
96 b18c1
Thanks much
Moderator
Re: Give me a hand on my GSR/EG (James Bond)
no your secondaries are not opening....not with a chipped p28.....you need to get a skunk2 intake manifold or a obd1 p72 to get them to work
Re: Give me a hand on my GSR/EG (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">no your secondaries are not opening....not with a chipped p28.....you need to get a skunk2 intake manifold or a obd1 p72 to get them to work</TD></TR></TABLE>
Yea I didnt think so. Thanks for the 2 cents chad
Re: Give me a hand on my GSR/EG (Dengar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dengar »</TD></TR><TR><TD CLASS="quote">ill trade you my p72 for your chipped p28 so you can hear the secondaries..
No No No
I have a P72 for smog. Im going turbo in a few weeks (waiting on my BB 50 trim) so Ill be selling it soon (maybe)
No No No
Re: Give me a hand on my GSR/EG (delLudeVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delLudeVTEC »</TD></TR><TR><TD CLASS="quote">open hood, rev engine on throttle body, look to see if iab actuator valve is moving. </TD></TR></TABLE>
haha I thought about this, but I was thinking; like VTEC they would only open under some type of load?
Well just for fun I pulled off the vacume line to the TANK and I gots Zero vacum.
I was wondering why my midrange was so "blah"
Skunk2, you win
Skunk2, you win
TSPeed Factory
at around 5700 rpms you should hear it kick in. also your car does not throw a code if you're IABs aren't hooked up or not working properly.
Moderator
Re: Give me a hand on my GSR/EG (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">at around 5700 rpms you should hear it kick in. also your car does not throw a code if you're IABs aren't hooked up or not working properly.</TD></TR></TABLE>
grrrrrrrrrrrrrrrrr....no it won't throw a code.....why cause he doesn't have a p72 in there...he has a chipped p28.....therfore the p28 does not know to look fo the iab's...
Re: (JDMspecs Eg6'er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMspecs Eg6’er »</TD></TR><TR><TD CLASS="quote">Sorry but i have to ask..........can i pass reff if my jdm gsr swap into my 92 civic if the IAB werent hooked up??</TD></TR></TABLE>
I dont know, Im about to go bar though. Ill let you know.
TSPeed Factory
grrrrrrrrrrrrrrrrr....no it won't throw a code.....why cause he doesn't have a p72 in there...he has a chipped p28.....therfore the p28 does not know to look fo the iab's...</TD></TR></TABLE>
it doesn't throw a code regardless of whether you use a P72 or not. now how might i know that you ask? because i ran my GSR motor without the IABs hooked up and a P72 and it didn't throw a code. neither did multiple of my friends that ran the same setup as me.
Ok, can someone explain this to me....
I've got a '95 GSR with the usual bolt on's (header/exhaust/intake). At around 5700 rpm I get that way cool GSR growl, and a big jump in power.
Now...is this the VTEC engagement point or the "secondary air intakes" opening? Or are these the same thing?
I've also heard from many people that the VTEC engagement comes on at around 4400rpm. And indeed, if I I'm in, say, third gear and accelerate under say half throttle, real slowly increasing the rpm's, right around 4400rpm I hear an extremely subtle "click". Although I don't notice much of an increase in power. So what's that?
I can't tell you how many fing mechanics/tuners/enthusiasts/employees of aftermarket parts companies (including APEX) I've asked and nobody can give a straight answer!
Anyone?
Anyone?
TSPeed Factory
Re: Give me a hand on my GSR/EG (jack sprat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jack sprat »</TD></TR><TR><TD CLASS="quote">Now...is this the VTEC engagement point or the "secondary air intakes" opening? Or are these the same thing?</TD></TR></TABLE>
its your secondaries opening.
maxheat
10
02-09-2005 12:55 PM
