damn!!! upper bolt hole on tranny cracked? how bad is this?
Munkyw3rkz.webs.com
1 Post
Re: damn!!! upper bolt hole on tranny cracked? how bad is this? (stockegsix)
i wouldnt sweat it too too much but keep a eye on iot...dont know about welding th etranny casing...maybe it would work who knows....
* B A N N E D *
Re: damn!!! upper bolt hole on tranny cracked? how bad is this? (SnoFlake EG)
weld fill the whole not too much just enough to close up the crack.. and retap it.. done it b4
Re: damn!!! upper bolt hole on tranny cracked? how bad is this? (ShowTymers619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShowTymers619 »</TD></TR><TR><TD CLASS="quote">weld fill the whole not too much just enough to close up the crack.. and retap it.. done it b4</TD></TR></TABLE>
many many thanks, although, Ive been thinking about this all day since i cracked it. Im glad someone has done it. thank you again sir!
Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">i would try to find a busted tranny and use it to replace the case</TD></TR></TABLE>
id do that. unless u know someone who can weld aluminum, then id go for the fill it with weld then drill and tap it. there was a thread about this not to long ago and alot of people had great suggestions of what to do and they had pictures of it.
Re: (stockegsix)
make sure you get it done asap, for example i could never figure out why my 2nd and 5th gear always act funny/slip out of gear from time to time...when i did my motor swap i notice that one of the bolt on the tranny was gone/broken....so i think 2 out of the 3 bolts will not hold the tranny good/strong and it could possible grind the gears over time?....
Re: (LSturboEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSturboEH2 »</TD></TR><TR><TD CLASS="quote">
there was a thread about this not to long ago and alot of people had great suggestions of what to do and they had pictures of it.</TD></TR></TABLE>
Might be talking about my thread.
https://honda-tech.com/zerothread?id=943834
if youre going to just run two bolts on it for now, find a bolt that can "plug" the other hole... because if u peak in the hole u can see the gears... u dont want dirt in there
i been running with 2 bolts and its still fine.... but theres a lot of stress marks that develop on the tranny over time.
Re: (usdm toilet)
My tranny (91 ls cable) has been running with only 2 holes for a while with a perfomance clutch, no probs yet. Mine is missing top tranny bolt, i see no gears though just a chunk of missing housing, it enough to make you wanna spit though. I need a gsr tranny anyway. I'm going to run it til it dies. if the other bottom hole gives, as long as it's not bad, I could still limp home with a very animated engine and tranny.
Re: (usdm toilet)
I dont think that the hole goes through, I dont see the inside of the tranny through the hole. Im just gonna get this hole welded shut
SoOHiGH
05-04-2005 02:13 PM
