99-00 OEM fog light wires
i bought an OEM 99-00 bumper today that came with OEM fog lights. The only problem is, is that the bumper didnt come with the with the other wires to hook up to the car. Is there any way I can just buy the wires for the fogs? Any help would be great Thanks
Re: 99-00 OEM fog light wires (Shikaruto)
There is a small brown harness by your cruise control under the hood and it has 1 wire. Tap that wire with the positive side from both foglights and just ground the negative side to the chassis. Then go to honda and purchase the switch which is around 15 bucks. Under your dash there is a harness for the switch just plug it in.
Re: 99-00 OEM fog light wires (mchuang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mchuang »</TD></TR><TR><TD CLASS="quote">There is a small brown harness by your cruise control under the hood and it has 1 wire. Tap that wire with the positive side from both foglights and just ground the negative side to the chassis. Then go to honda and purchase the switch which is around 15 bucks. Under your dash there is a harness for the switch just plug it in.</TD></TR></TABLE>
But he'll still be missing the wiring harness that goes to the column / headlight switch, so he'd have to remember to turn them on and off manually.
You can see if the honda dealer may have the harnesses you need, but sometimes it's hard to get parts for the accessory kits. My spoiler was missing something, and it took two weeks for them to find a part number for it.
You might just want to buy a knockoff kit to get the wires. I know they're pretty cheap, and you'll have extra lenses if something gets broke or whatever.
i have all the oem wiring with switch if you're interested. i bought the kit just for the lights, so i have no need for the wiring.
superchargedY8
04-07-2009 07:09 PM
