D16y8 compression test done. #'s too high?
I finally got off my lazy *** and did a compression test on my d16. All the cylinders were 205 across the board. I know it's good that they're consistant, but don't you think that's a little high?
Re: D16y8 compression test done. #'s too high? (zseeanz)
Were you watching a boost/vaccum gauge? were you near 0 on it in the vaccum side when you performed the test? Not sure if this could affect the test.
Maybe carbon build up?
Not sure
Not sure
Re: D16y8 compression test done. #'s too high? (ILLICON3000)
how many times did you crank it? all you want from a compression test is consitency the actual #'s dont "really" matter
Arent you only suppose to turn the car over 3 times?
Either way dont worry about it as long as the numbers are together you have a good motor.
Example:
205 200 205 203 (good motor)
Example:
Risky Business
Re: D16y8 compression test done. #'s too high? (Luserkid)
My mini-me made 215 across the board. This is with 10.1:1 compression. The Y8 has 9.6. Those numbers are good, it means you have a healthy motor
aj345
06-02-2013 07:58 PM
