no voltage to injector clips
Old 09-15-2004, 05:21 PM
Btothe3rdDegree's Avatar
Default no voltage to injector clips
anyone know what will cause this? there is no voltage at all flowing to the injector clips
Btothe3rdDegree is offline
Old 09-16-2004, 05:50 AM
EE_Chris's Avatar
Default Re: no voltage to injector clips (Btothe3rdDegree)
Blown fuse; open/shorted wire; ignition switch not turning on Main Relay
If you don't have voltage at the injectors, then you probably don't have it at the ECU or IACV too as all these components are fed battery voltage through the Main Relay. The Main Relay gets its signal from the ignition switch.
So when you turn the key on, you don't get the CEL on for 2 seconds while the fuel pump primes too, correct?
EE_Chris is offline
Old 09-16-2004, 06:28 PM
Default Re: no voltage to injector clips (EE_Chris)
nope the fuel pump primes and i replaced the main relay too
i am totally lost why it wont work
help please!!
Old 09-17-2004, 02:54 AM
EE_Chris's Avatar
So then - the injectors aren't getting +12v or they aren't getting a ground signal?
If they aren't getting +12v, but your fuel pump is priming, then start tracing the feed wire from the Main Relay to the junction connector that feeds the ECU, injectors and IACV.
Did you install a resistor box, by chance?
EE_Chris is offline
Old 09-17-2004, 03:54 AM
yep install a resistor box, what i did was i got a multimeteter turned the car to the on posistion pulled a injector connector clip put the positive to the yellow black wire and the negative to the negative on the battery and got no voltage.
Old 09-17-2004, 04:48 AM
EE_Chris's Avatar
What about the voltage going INTO the resistor box? The resistor box feeds the injectors so just start back tracing through the wiring until you find where voltage stopped.
EE_Chris is offline
Old 09-17-2004, 07:01 AM
it sound like i am doing it right? positive to the yellow black wire and negative to the negative battery terminal?
Old 09-17-2004, 07:07 AM
kinda of a newb question, does the cap on the dead end connector have to be on?
Old 09-17-2004, 08:17 AM
EE_Chris's Avatar
Not really knowing about the cap (though a possibility as the cap could be what makes it a 'junction' connector) - but do you at least have +12v going to one wire in that connector?
EE_Chris is offline
Old 09-17-2004, 08:44 AM
i will have to check, and find that cap!
Old 09-17-2004, 09:25 AM
gtfourmn's Avatar
If you have a helms manual there is a trouble shoot that you can followed to find out what is wrong.
As for myself, I had a problem similar to yours a couple of months ago in my integra after I swapped out some 450s and popped in the stockers. It ran great for a couple of days then the check engine light came on and after trouble shooting I found out I wan't getting any voltage to one of the injectors. I had to replace my ecu, and problem fixed.
gtfourmn is offline
Old 09-19-2004, 06:17 AM
Default Re: no voltage to injector clips (turbine)
missing cap on the dead connector is what it was
Old 11-24-2004, 07:18 AM
atli126's Avatar
what are you talking about here, sorry i dont understand , im having the same problem
thanks
bret
atli126 is offline
Old 11-24-2004, 07:51 AM
klungemonger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Btothe3rdDegree &raquo;</TD></TR><TR><TD CLASS="quote">missing cap on the dead connector is what it was </TD></TR></TABLE>
Yeah, it's not just a "cap", in fact it's not really a connector at all... it is a bus block (power distribution terminal.) The cap is what transfers the 12V from the input wire to all the other wires.
klungemonger is offline
Old 11-24-2004, 08:59 AM
Syner-G-Racing LLC's Avatar
Default Re: no voltage to injector clips (klungemonger)
its called a shorting block.
Syner-G-Racing LLC is offline
Old 11-24-2004, 09:45 AM
Steadfast's Avatar
Default Re: no voltage to injector clips (Syner-G-Racing)
Dang..I learned something today!
Steadfast is offline
Old 11-28-2004, 06:50 AM
turboteg2nv's Avatar
Default Re: no voltage to injector clips (Steadfast)
bump for having a similar problem: https://honda-tech.com/zerothread?id=1068709
turboteg2nv is offline
rdssk8rcs1
04-10-2009 11:23 AM
JDMB20TDA
08-18-2007 08:45 AM
FastAsleep
17
08-28-2006 04:40 PM
vesperfx
Audio / Security / Video
26
05-24-2006 01:09 AM
digitalcongo
11-14-2003 04:27 AM
Quick Reply: no voltage to injector clips
  • Ask a Question
Question Title:
Description:
