Hood Cooling and Hood Locks
Has anyone who has done that hood cooling prop with the washers and extended bolts have a problem with the mr. gasket hood lock fitment and alignment after?
I need all the extra cooling I can get and I'm worried that the locks won't line up correctly if I do this.
People who had previous hood locks, and did the spacers, please comment here.
Thanks.
Thanks.
Re: (pdiggitydogg)
true, but the hood looks have very very little clearance as-is.
is there anyone who has personal experience with this because that's what i'm looking for.
Re: Hood Cooling and Hood Locks (all stock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock »</TD></TR><TR><TD CLASS="quote">Has anyone who has done that hood cooling prop with the washers and extended bolts have a problem with the mr. gasket hood lock fitment and alignment after?
Thanks.</TD></TR></TABLE>
i have the same problem i just dont lock my hood i am also running the same exact setup as you
Re: Hood Cooling and Hood Locks (bonta-kun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonta-kun »</TD></TR><TR><TD CLASS="quote">
i have the same problem i just dont lock my hood i am also running the same exact setup as you </TD></TR></TABLE>
so you weren't able to keep the locks when you ran the spacers?
no sir what u can do though is grind the nuts that hold the locks to the car at a angle so that u can screw them in a angle shape and that would make it able for u to use the locks
