throwin 2 codes after da swap is done.. HELP!!!
couple of my friends and I just finished up on my swap.
https://honda-tech.com/zerothread?id=1016296
well, da check engine is light is on and two codes were 15 and 23 which are
the ignition output sensor and a knock sensor.
my question is how can i get rid of da knock sensor?
i've read that i can just remove a pin from the ecu.. correct?
could knock sensor affect at all on my Vtec kickin in? becuz i can't really feel or hear my v-tec..
please help me out.. any kind of info would help on both of the codes..
thanks
thanks
Knock sensor won't put the engine in "limp" mode. You can either get rid of it by using the p28 ecu which doesn't use the knock sensor, or doing what i had done and wired it to the ECU.
Re: (eyeamvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eyeamvic »</TD></TR><TR><TD CLASS="quote">Knock sensor won't put the engine in "limp" mode. You can either get rid of it by using the p28 ecu which doesn't use the knock sensor, or doing what i had done and wired it to the ECU.</TD></TR></TABLE>
i have a p28 but could i just use that without chippin it?
if not, where do i wire to the ECU?
Re: (92eh3si)
http://tech.hybridgarage.com/t...inout
Bottom of the page, and use the P72 or send your P28 to Hondata.
Re: (HybridEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridEJ1 »</TD></TR><TR><TD CLASS="quote">http://tech.hybridgarage.com/t...inout
Bottom of the page, and use the P72 or send your P28 to Hondata.</TD></TR></TABLE>
thanks.. i am gonna keep my p72 i think.. and chip my p28 later when i go turbo..
anyways, i will remove the wire for knock sensor and see how it goes..
thanks a lot
thanks a lot
Re: (SprayinCX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SprayinCX »</TD></TR><TR><TD CLASS="quote">i don't see how removing a wire from the harness is going to tell the ecu not to read a knock sensor. </TD></TR></TABLE>
not from da harness.. from the ECU..
Location: chillin in that city called queen creek, but homes the atl
Re: (92eh3si)
why don't u just hook the knock sensor up u are running a p72 ecu or is it hooked up and its still throwing the code
