dizzy is fired sooo!!!!
ok what dizzy works with a jdm d15b motor ..so i can get one asap ..my car cranks but no start..changed plugs, no smoke ..so i know its the dizzy
Re: dizzy is fired sooo!!!! (jdmEFnine1)
i have one that i can sell you.
let me know
its off a jdm d15b motor.
we put the motor in a crx and we used the crx si dizzy.
let me know
usually the first thing to go in the distributor is the coil,...a bseries coil from my local autoparts store ran me around 60 bucks,..might be cheaper for a dseries,..i would try getting a new coil first,..cheaper than getting a new distributor,...btw how are you checking for spark?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmEFnine1 »</TD></TR><TR><TD CLASS="quote">im checking it buy putting a screw driver in the wires</TD></TR></TABLE>
take a spark plug out,...now put it in the boot of the sparkplug wire,..hold it like an 1/8 of an inch away from a good ground,..have a friend turn the key to crank the motor,..look in between the spark plug and the ground and see if you can see a spark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmEFnine1 »</TD></TR><TR><TD CLASS="quote">ok i'll do that ..if nothin then what</TD></TR></TABLE>
its not a for sure thing but most likely your coil is done because like i said above,..usually the first thing to go is the coil,...go get a new coil from autozone/pepboys/etc
Re: dizzy is fired sooo!!!! (2.0 EK)
ok cool yeah i was just talk to my friend he said the same thing happen and it mite be my coil so i hope that it.else im screwed
Re: (jdmEFnine1)
if it doesn't work, i have one off a jdm d15b motor. just let me know if you want it.
the one from the crx won't work cause it won't plug into your obd1 harness.
