Problem with turn signal...
Ok well the car is up and running now and I have a problem with the turn signals...when I go to signal instead of each of them turning on individually they both turn on at the same time...Is it a fuse or something more serious?
Re: Problem with turn signal... (SpugenEG)
with this seriously its crosswire. Check under your fuse panel under the steering and then check your switch by removing the steering cover and check if the wire looks original or has it been tap; meaning cut or re-wire...
efcivic317
12-02-2010 02:25 PM
ChevelleSSLS6
04-09-2009 07:44 PM
