93 civic ex problem.
First off this is a friends car but ive worked on hondas before so im pretty familiar with them, the prop them is the seedometer isnt working. I made a quick glace at 12am with a flash light and didnt see anything un hooked. But yeah its a 93 ex. She just bought it and it has some mods done to it. I think a new motor was put in it, it said D16 and them some numbers i forgot. What came in these stock? Back to the speedometer question, what should i check? Dont hate on my fr being a V8 guy lol well thanks for any help!
Re: 93 civic ex problem. (2.0 EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.0 EK »</TD></TR><TR><TD CLASS="quote">is she throwing a check engine light? it could be the Vehicle speed sensor,..the VSS wiring,..or the gauge cluster </TD></TR></TABLE>
Make sure that your getting continuity to the VSS, if you're not then check the wiring before replacing the sensor.
Re: 93 civic ex problem. (JDM Ninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Ninja »</TD></TR><TR><TD CLASS="quote">Check the Vehicle Speed Sensor.
Also, a 1993 Civic EX comes with a D16Z6 motor, stock.</TD></TR></TABLE> Ok well i think it said D16something8 i remember there being a 8. Looked to be a swap becasue of the writing on the valve cover.
Re: 93 civic ex problem. (MEATWAD_00GT)
its probably the vss, the motor that she probably had swapped if it says d16 something 8 is most likely a D16Y8 SOHC VTEC from a 96-00 civic ex
Location: Your mommas bed, that might be true too ..., So Cali, USA
where is the VSS located ?? my speedo isnt workin either , and my rpms work a lil its goes up to 4k and restarts again from 1
