98 DX Manual Rack & Pinion fit on a 00 EX?
Will the manual steering Rack & Pinion for a 1998 Honda Civic DX..... Fit on a 2000 Honda Civic EX?
I've had my PS Rack&Pinion looped for some time now and have finally decided to swap it out for an actual manual rack.
Re: 98 DX Manual Rack & Pinion fit on a 00 EX?
Yes they will fit, but you have to use the manual rack bushings and clamps. You also need the cross joint that connects the pinion shaft to the steering column that came with the manual rack. You may need to widen the bolt hole of the clamp to match the holes on the subframe.
Technical Hero
Here's the reverse but may help you in getting around
http://repo.jackmoves.com/v/erik/album106/album119/
fkncivic
09-23-2020 11:03 AM
james_moore
02-22-2012 11:52 AM
