difference between 2000 civic EX and SI engine wire harness
Old 07-09-2013, 05:20 PM
sanjiyan69's Avatar
Default difference between 2000 civic EX and SI engine wire harness
I was looking at on majestic Honda and I noticed that they are the same (I chose 2DR EX vs SI)
So what is the part number of the engine wire harness? There are several and I'm not sure.
Thanks.
http://www.hondaautomotiveparts.com/...5=WIRE+HARNESS
Old 07-09-2013, 05:49 PM
cbaber's Avatar
Default Re: difference between 2000 civic EX and SI engine wire harness
They are the same. The difference occurs on VTEC vs non VTEC vehicles.
32200-S04-A52
Old 07-09-2013, 06:16 PM
sanjiyan69's Avatar
32200-S04-A52
Thanks. Now that is the one that goes from ECU to the motor? It looks like there is a disconnect in the drawing.
Also what is the difference between the 2 door and the 4 door ex engine wire harness?
Thanks.
Old 07-10-2013, 05:16 AM
kyden's Avatar
They are not the same. a 99-00 civic ex will have the small rectangle plug for the distributor. a 99-00 si will have a square plug.
Old 07-10-2013, 08:23 AM
n/a2boost's Avatar
32200-S04-A52
they are not the same...theres two things that are different..
Originally Posted by kyden
They are not the same. a 99-00 civic ex will have the small rectangle 8 wire plug for the distributor. a 99-00 si will have a square 10 wire plug.
this ^^^^ and the crank sensor plug is 2 wire fir the si and 3 wire for every thing else..
Old 07-10-2013, 05:30 PM
sanjiyan69's Avatar
The plug issue can be addressed with a distributor adapter. How can I get around crank sensor plug issue if I were to use this in an em1 with a b20/vtec?
thank you for your help.
Old 07-10-2013, 07:42 PM
civicexkid1's Avatar
99-00 civic ex and 99-00 em1 use the same harness everything is pretty much plug and play but you have to extend 2 sensor wires and the distributor plug might be true cause i have seen something about it being different everything else works you just need a ecu from the si
Old 07-11-2013, 06:34 AM
kyden's Avatar
you can't say they use the same harness and say some plugs are different. that is illogical.
Old 07-11-2013, 07:02 AM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
Your advice giving card is revoked!!
Old 07-11-2013, 11:52 AM
sanjiyan69's Avatar
lol nice ^^^
Anyone has any idea on how to address the 3 wire vs 2 wire crank position sensor issue? I'm putting this gsr/b20 setup in a SI and in my previous setup (in a 96 ek) I didn't have to deal with this problem.
Thanks again.
Old 07-11-2013, 12:37 PM
n/a2boost's Avatar
You could do the bypass trick. http://technet.ff-squad.com/ckftrick.htm
whyS0serious
13
01-12-2015 06:20 PM
superiorx120
06-12-2011 08:54 PM
irishone
01-31-2007 12:43 PM
OPTION2ek V.2
04-18-2005 05:41 PM
romeirome1
12-15-2003 07:59 AM
Quick Reply: difference between 2000 civic EX and SI engine wire harness
