Auto tranny woes
Auto tranny woes
Have a 98 civic auto tranny.
I've searched around but can't quite seem to find someone with my issue. If you go easy on the tranny sometimes it will shift through gears fine. If you are giving it any reasonable amount of pedal it is almost like it hits rev limiter around 3500 or so and will not shift into the next gear, however if you let off the pedal it will shift then you can lay back into it. If you try and go wot it will redline and not shift nor accelerate
Does this sound like the linear shift solenoid? I've tried replacing trans fluid with no luck.
