Eg/ej cluster help !
Hey guys I swapped out my dx cluster last night for an ex cluster seemed to work fine and I opened it and installed LEDs and put it all back together and now everytime I turn on the switch the temp needle will shoot all the way up and stay there even after I press it down with my finger. I swapped back to my old cluster to check if my temp was actually that high but no car is normal .
Any info on how to fix this or maybe I put it back wrong or do I have to get a new gas/ temp gauge ?
Thanks!
Thanks!
O.G. triple O.G.
Re: Eg/ej cluster help !
the temp gauge is bad. That gauge can be purchased from Honda for around $60 or so. For that much, you're better off getting another used cluster.
it's more likely that OP messed up while installing LED's....
led strips instead of bulbs how does that work ? is this some custom project ?
Yeah custom project .
O.G. triple O.G.
^^^ if your old cluster works fine and the new one has an issue with the temp.....IT'S THE GAUGE. Too bad you can't swap one onto the other.
MTarry
11
01-15-2013 06:46 PM
