92-95 master cylinder 15/16" upgrade info
Today I confirmed that the master cylinder out of a 90-91 civic ex with rear discs is a direct bolt in and 15/16". I'm planning on putting discs in the rear so I wanted the bigger master, but didn't want to change out the entire booster. From what I can tell the booster is the same part between the 90-91 and the 92-95. So I bought it and went for it. It's Autozone part number M52517, and after my military discount and the core charge, it cost me 47ish for the entire replacement, plus fluid. One added beny, the autozone came with the new cap and res!
Re: 92-95 master cylinder 15/16" upgrade info
This is the exact setup I went with on my car also. Make sure if you do rear disks though to change to a 40/40 prop valve or the rear calipers won't engage properly.
I am going to "attempt" to change the rear hubs to the disc ones from the 92 si discs and go all stock, but I hear that they strip easy so we'll see how it goes
skill178
16
10-09-2011 04:38 PM
