97 civic ex, y7 engine, y8 intake p06 ecu
Setup:
1997 Honda Civic EX
y7 engine
y8 engine harness
y8 intake manifold
p06 ecu
1 o2 sensor in header
no crank position sensor
PROBLEM:
throws a code 1
any suggestions?
BTW: not my car, dropped in the y7 just to get rid of the car
1997 Honda Civic EX
y7 engine
y8 engine harness
y8 intake manifold
p06 ecu
PROBLEM:
throws a code 1
any suggestions?
Re: 97 civic ex, y7 engine, y8 intake p06 ecu
resetting the ecu works but the code comes back when attempting to start.
lol. yes the o2 sensor is plugged in.
What adapter are you using between the harness and the ECU? Have you verified the pins and wires are all intact? Have you made sure the plug on the O2 sensor, as well as on the engine harness are both clean and free of corrosion? Have you checked those wires?
wires on the jumper are fine. o2 plug is fine and clean. tried 2 different o2 sensors and 2 different ecus. all same result.
In that case, it's a problem between the ECU and the O2 sensor plug. Check for continuity on all four wires, from the plug to the ECU plugs before the adapter harness.
edwardjo86
11-19-2012 07:31 PM
c1civic
12-27-2006 03:27 PM
