D16y8 99 civic ex will not start (no crank problem)
Old 07-12-2013, 11:08 AM
killrroyale's Avatar
Default D16y8 99 civic ex will not start (no crank problem)
hey guys i need some help. i just drove my car this morning. parked it and now it will not start. i have had the starter checked and solenoid checked i have good voltage in all the right places at the key at the starter at the fuses and at the clutch peddle switch also tested it there. turn the key on and i hear the fuel pump kick up lights come on and everything seems to be right when the i try to start it i can also tell that the heater relay is cutting in and out like it should so there is power getting there. i get nothing no click or anything. thanks for the help.
Old 07-12-2013, 11:17 AM
Former User's Avatar
Default Re: D16y8 99 civic ex will not start.
The starter fails to crank the engine, right?
Start by checking whether the rubber stopper that presses on the starter switch at the top of the clutch pedal has fallen out.
Old 07-12-2013, 11:19 AM
i checked that. took it off and made sure that it disengages and engages.
Old 07-12-2013, 11:21 AM
Test whether battery voltage reaches the starter solenoid when the clutch pedal is down and the key is in ON(III). Does the solenoid click under these conditions?
Old 07-12-2013, 11:23 AM
no
Old 07-12-2013, 11:28 AM
Have you tested the clutch switch itself? For example, under the conditions I mentioned, is there battery voltage on both sides of the clutch pedal switch?
Old 07-12-2013, 11:31 AM
sidewayz6.6's Avatar
Did you check for spark?
Old 07-12-2013, 11:32 AM
How could he possibly check for spark if the starter won't crank/turn the engine?
Old 07-12-2013, 11:39 AM
Default Re: D16y8 99 civic ex will not start (no crank problem)
Ok removed the clutch switch tested as u said I have no voltage either side when key is turned to III. What I did before was make a jumper from one of the terminals to a batt + then connected the other to the volt meter and it did engage and disengage. So do u think me not having 12v on there now the switch is bad?
Old 07-12-2013, 11:43 AM
This^ means voltage never reaches the clutch pedal switch.
Test your ignition switch. The ON(III)/START position may be the problem.
Old 07-12-2013, 11:55 AM
Ok I have tested that and I have voltage to the black/white wire in position III then on voltage when key is in position II. All other terminals have 12.75v in position II. and when turned to position III the black/white terminal showed 12.77v
Old 07-12-2013, 11:57 AM
With the pedal switch unplugged, you need to probe for voltage at both terminals (individually) of the unplugged 2P wire harness connector (not switch). Is that what you did? If not, redo your voltage tests this way with the key in ON(III).
Old 07-12-2013, 12:03 PM
Ok I tested the two wires in position III. there is no voltage either side. Pink/silver or black/white.
Old 07-12-2013, 12:30 PM
This^ is the cruise control switch. The starter switch (Blu/Blk and Blk wires) is located higher up on the clutch pedal. Check whether the rubber stopper for the relevant starter switch is missing.
Old 07-12-2013, 12:51 PM
Oh d&*# Ok I'll look again.
Old 07-12-2013, 12:55 PM
Spade's Avatar
Do you have a car alarm or older car alarm harness in place?
Old 07-12-2013, 01:11 PM
Ok fixed it man. It would have taken me forever to look up that freaking high on the clutch. The rubber stopper just crumpled in my hands. Thank you so much. A nut and bolt I have laying around will fix.
Old 07-12-2013, 02:28 PM
dirtygerman
06-17-2011 07:04 PM
ftrms
15
12-22-2010 04:05 PM
stl eh2
12-03-2009 10:07 AM
fullboostin
01-04-2008 03:49 PM
03K24A4EX
05-26-2006 04:47 AM
Quick Reply: D16y8 99 civic ex will not start (no crank problem)
