b20 oil pan on b16a? will it fit?
Re: b20 oil pan on b16a? will it fit? (hamburgler)
The b16a pan is not the same as far as part number, but b16a pan will fit. They all share the same gastket #. 11251-P30-004. Oil dipstick will work.
Trust me i know b/c i had a turbo b16 in my hatch, and when i pulled it out to put in my coupe car i put an ls{witch is the same as a crv pan} back on my b16 motor. The b16 IS the same as an ls[or crv] but are different from the GSR or Type R pans{witch also match each other}. The reason for this is b/c the only two B-series motors with a crank girdle from the factory is the GSR-Type R motors. The b16 and ls motors do not have a factory crank girdle, that is also why, on an lsvtec setup when you add a girdle, you have to use a GSR or Type R pan, p/u, and windage tray:} B/C that is what i put in my hatch when i pulled my b16 out.
Re: b20 oil pan on b16a? will it fit? (becoming)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by becoming »</TD></TR><TR><TD CLASS="quote">Trust me i know b/c i had a turbo b16 in my hatch, and when i pulled it out to put in my coupe car i put an ls{witch is the same as a crv pan} back on my b16 motor. The b16 IS the same as an ls[or crv] but are different from the GSR or Type R pans{witch also match each other}. The reason for this is b/c the only two B-series motors with a crank girdle from the factory is the GSR-Type R motors. The b16 and ls motors do not have a factory crank girdle, that is also why, on an lsvtec setup when you add a girdle, you have to use a GSR or Type R pan, p/u, and windage tray:} B/C that is what i put in my hatch when i pulled my b16 out. </TD></TR></TABLE>
Good information!
Good information!
Fantastic420
10-03-2009 07:54 PM
SwedBoy2999
10-13-2005 06:21 AM
