leather GSR front & rear seats into a 93 DX hatch.
i was wondering what id have to do to make the front and rear GSR seats fit into a hatch. i think on the fronts i have to switch the seat rails or can i just bolt them in? but on the rear do i bolt them in or what? im not to sure about that. any help would be great!
Re: leather GSR front & rear seats into a 93 DX hatch. (Squallie)
Its all direct bolt-in. The rear you might have a small problem with the hooks. But the front drop right in.
Re: leather GSR front & rear seats into a 93 DX hatch. (Chilly61383)
so on the front i just unbolt the driver and passenger seats and then bolt up the GSR in the factory spot? sounds easy and i hope it is. but gimme more info about the rear seats, like what i may need to remove or whatever . anybody else feel free to put in your opinions or advice that you learned if you did the swap!
the fronts will be a direct bolt on. but the back ones won't fit. the hooks won't match up, there will also be a inch gap all around the seat. i think the 4 door gsr seat might fit into a eg hatch. im not sure
Re: leather GSR front & rear seats into a 93 DX hatch. (futurefastguy)
yea the seats are comming from a four door if im not mistaken, i should of listed that earlier, so if they are from the 4dr then would it be a direct bolt up?
yeh the front 2 bolt up directly and the rear lower section has a big gap and hook doesnt match where the 10mm bolt goes...just use a civic bottom section and integra top sections on the rear and it will be perfect...i have gsr seats in my hatch
grizzy225
11
10-10-2007 06:15 PM
