sawpping gsr cluster into ek. need help asap
Old Jul 1, 2005 | 09:47 AM
syked's Avatar
Default swapping gsr cluster into ek. need help asap
im in the process of repinning my civic harnesses. im putting a 94 into my 00 civic. i used BlueIntegraBoy's guide https://honda-tech.com/zerothread?id=1053318
it says i need to take E2 RED/BLUE Climate Control and pin it to D5. This E2 is part of a 5 pin harness that is green, exactly like the yellow SRS plug. However, i cant seem to get the pin out so i can repin it. anyone know how to take the pins out of the smaller green harness?
Old Jul 1, 2005 | 10:00 AM
syked's Avatar
Default Re: swapping gsr cluster into ek. need help asap (syked)
anyone?
Old Jul 1, 2005 | 10:01 AM
Sean Juan's Avatar
just cut the red/blue wire off the plug and connect it to the other red/blue wire
Old Jul 1, 2005 | 10:02 AM
Sean Juan's Avatar
Default Re: swapping gsr cluster into ek. need help asap (GRIP KING)
For mine, it went to cruise control, but i have a 92-95. none of the pins fit my plugs so i cut and reconnected them all and it works fine.
Old Jul 1, 2005 | 10:09 AM
syked's Avatar
what other red/blue wire? i dont have the teg harnesses. ive got a 00, so all i had to do was repin the wires to different locations. i got everything else out of the blue harnesses fine, but i cant get the pin out of the smaller green harness
Old Jul 1, 2005 | 10:13 AM
Sean Juan's Avatar
Oh deng. Did you try a paperclip?
Old Jul 1, 2005 | 10:14 AM
syked's Avatar
i tried a bobby pin. i stuck it in all the holes and lifted up/down on the bobby pin and gently pulled the wire, cant get it out.
Old Jul 1, 2005 | 10:19 AM
Sean Juan's Avatar
Default Re: (syked)
stick a paper clip in under the pin and press it down while pulling the wire out. should work.
Old Jul 1, 2005 | 10:28 AM
syked's Avatar
it wont budge ?????
Old Jul 1, 2005 | 10:29 AM
Sean Juan's Avatar
Default Re: (syked)
it can be tricky. try shaving it down a lil. rub it against concrete to make the end of it more flat
Old Jul 1, 2005 | 11:30 AM
syked's Avatar
alright, i got it out. however, the pin a different than the others. on the blue harness, the pins have a part that is slanted up so it makes contact with the circuit thing on the cluster. this pin from the other one does not, so how is it spose to work?
Old Jul 1, 2005 | 11:42 AM
Sean Juan's Avatar
Default Re: (syked)
might have to use another pin and cut that one off ... then connect it.
Old Jul 1, 2005 | 12:21 PM
syked's Avatar
what do i do with the rest of the green harness? also, on the civic harness, B2/PINK/WASHER FLUID... what do i do with this? it doesnt say reconnect it anywhere? do i leave it where it is?
Old Jul 1, 2005 | 12:44 PM
Sean Juan's Avatar
Default Re: (syked)
I don't think that will work. Just leave it unplugged.
Old Jul 1, 2005 | 12:48 PM
syked's Avatar
Default Re: (GRIP KING)
alright.
1) I took E2 (RED/BLUE) CRUISE CONTROL pin out of the small green harness and stuck it into D5. however, it has a different pin, so it doesnt stick out and make contact liek all the other pins do. what do i do about this?
3) What do i do with the rest of the green harness? it contains ground, headlights on, power.
i think thats it for now.
Old Jul 1, 2005 | 12:55 PM
gabebauman's Avatar
Default Re: (syked)
Don't worry about the rest of the green harness. Mine is just hanging behind the cluster.
Old Jul 12, 2005 | 08:46 PM
AnclyT's Avatar
Default Re: (gabebauman)
This guy is incompetent with cars, I sold him my perfectly working GSR gauge cluster and after he tried installing it into his civic, (which he doesn't know how), he messed up the perfectly working gauge cluster I sold him and wants more than a full refund.
I respectfully refused, and listened to his explanation. But after he told me he tried messing with the cluster, and tried rewiring and repinning the cluster, I knew that was the problem
For future reference, please get professional installation or help before you mess something up and blame it on the source.
I have many vouches and have dealt with MANY transactions which have YET ended in dissatisfaction. I do not scam and especially not for some chump change cluster.
Please check out the gauge cluster again with anyone with car sense and most likely you messed up on your part.
I know I didn't do anything wrong.
Old Jul 13, 2005 | 05:50 AM
gabebauman's Avatar
Default Re: (AnclyT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnclyT &raquo;</TD></TR><TR><TD CLASS="quote">This guy is incompetent with cars, I sold him my perfectly working GSR gauge cluster and after he tried installing it into his civic, (which he doesn't know how), he messed up the perfectly working gauge cluster I sold him and wants more than a full refund. </TD></TR></TABLE>
Who are you talking about here?
Old Jul 13, 2005 | 07:05 AM
mike1114's Avatar
hey if you really for sure fucked up the cluster, I'll buy it for cheap.
I need the needles for a project I have.
Old Jul 13, 2005 | 07:11 AM
saxqtzk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman &raquo;</TD></TR><TR><TD CLASS="quote">
Who are you talking about here?</TD></TR></TABLE>
i think he's referring to syked perhaps.
Old Jul 16, 2005 | 12:26 PM
syked's Avatar
if anyone is incompetant, its you, because you obviously dont know that repinning a harness has nothing to do with messing with the actual cluster. i have a 00 civic, the civic harness has the same size harness as the integra harness, therefore, all i need to do is repin MY CIVIC HARNESS. i never touched the cluster, so stop saying i messed with the cluster cause i didnt, the only thing i messed with is MY CIVIC HARNESS. inproperly repinning the harness could of been the problem, however, i borrowed my friends 97 gsr cluster, plugged it in and it worked fine. therefore something is wrong with your cluster. also, you stated you never opened the cluster up. however, if you look real closely, there is a sticky residue around the edges of the gauges faces. as well as sticky residue on the sides on the needles, which are not visible unless you tilt it downward. so, dont sit there and say i have no idea what im doing. everything ive installed on my car so far was installed by me. no im not a pro, but i know what the **** im doing, and if i dont, i ask questions to find out for sure before i do anything else. maybe if you're so worried about your reputation, you shouldnt sell broken items. nuff said.
Old Jul 16, 2005 | 02:13 PM
BlueIntegraBoy's Avatar
You need to cut off the red/blue CC wire and connect it with a wire that you won't be using in your EK, such as your pink washer fluid wire. Take that connected wire and move it to the cruise control slot. I did this with my friend's EX and it worked fine.
Old Jul 17, 2005 | 09:02 AM
syked's Avatar
did that, and it worked fine in my friends cluster. my wiring is all correct. now all i need is a working cluster.
Old Jul 23, 2005 | 02:52 PM
gabebauman's Avatar
Default Re: (syked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syked &raquo;</TD></TR><TR><TD CLASS="quote">did that, and it worked fine in my friends cluster. my wiring is all correct. now all i need is a working cluster.</TD></TR></TABLE>
Same thing I had to do. My buddy has a 94 ls so I hooked his cluster up to my car and sure enough...all the gauges worked fine. I ended up buying another used cluster locally for $40. I was able to hook it up before I paid the dude...and everything went smooth.
kdrlinus
Jan 18, 2008 06:18 PM
rwcdrums
Aug 31, 2004 11:16 AM
BLUE EH3
Aug 25, 2004 04:39 PM
Fuster_Cluck
Apr 22, 2003 08:56 PM
acuracy389
Oct 6, 2002 07:46 AM
