d16y8 t-stat housing...
Farts in the shower
Alright, initial problem: radiator fan doesn't turn on and I tested the relays and those were good. I then jumped the harness and found that the fan turned on so it lead me to believe the fan switch (whatever its called ) is bad.
Now here is the problem: I removed the air intake and some of the radiator tubing and go to the sensor...now its at a weird angle and I couldn't get the sensor off with a cresent wrench so I went and bought a wrench and socket and those didn't fit due to the lip on the sensor. So I had the bright idea of taking the t-stat housing off the engine and that I might be able to get a better angle on the sensor....yea right.
Now I tried and tried but this damn thing will not budge so I looked on http://www.hondaautomotiveparts.com and saw the price of a new t-stat housing (10 bucks) so I ordered one and they are out of stock, then I tried autozone, napa, kragen etc and they are not able to order them either. Any suggestions guys...I have everything patched back up but I need to fix this sensor (which is already bought) and so my car doesn't overheat .
Also will any other d-series t-stat housing fit with the fan switch? Also anyone willing to sell one to me or offer any suggestions on how to remove this damn sensor?
Re: d16y8 t-stat housing... (.ken)
Farts in the shower
Re: d16y8 t-stat housing... (perlmeistere81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perlmeistere81 »</TD></TR><TR><TD CLASS="quote"> http://slhondaparts.com/browse...=true
I have had a lot of success with these guys ken. </TD></TR></TABLE>
Ordered it...hopefully they have it in stock . Thanks for the link .
I had the same problem, bought a new one and went to match it up at kragen, the socket size that worked for me is 15/16, cost me 6 bucks just to get that sensor out. i also have a y8 motor, so that socket should work...(deep socket)..
Re: d16y8 t-stat housing... (oneforce)
hey dude, if you are looking to buy that sensor, i work at kragen and ill be at work tommorrow, ill give you the part number u need...or simply call kragen and tell them to look up the sensor in the nieoff book...
hmtcrxsir
04-29-2009 06:48 PM
groundedcivic91
03-26-2004 04:09 PM
hardboiled egz
11
06-17-2003 10:08 PM
