Honda charge alot for changing an axle?
Re: Honda charge alot for changing an axle? (Hatch It)
why not use the money that u were going to spend to install the axel on tools?
u only need couple
u only need couple
This is one hell of a crazy idea, but maybe you can call up your local Honda Dealership and get a quote!
Prices vary everywhere and changing an axle isn't that hard. Most ANY mechanic can do it. At the dealership, you'll be paying an arm + a leg and maybe some money. I say just let your mechanic do it. Not that hard of a job...
i'd offer to do it for $40 if you were in cali
Re: Honda charge alot for changing an axle? (Advan06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Advan06 »</TD></TR><TR><TD CLASS="quote">This is one hell of a crazy idea, but maybe you can call up your local Honda Dealership and get a quote!
i'd offer to do it for $40 if you were in cali </TD></TR></TABLE>
I tried, they cant do them over the phone apparently?
By the time my mechanic could do it i could have rented a car, driven to cali, paid you the 40 bucks to change my axle, and drove back.....
How much you think they will charge about? Like give me a number to work with, or any good mechanics in the west chester area (PA)...gah im desperate...and im afraid i will mess it up if i do it myself...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch It »</TD></TR><TR><TD CLASS="quote">
How much you think they will charge about? Like give me a number to work with, or any good mechanics in the west chester area (PA)...gah im desperate...and im afraid i will mess it up if i do it myself... </TD></TR></TABLE>
axel change are easy
the hardest part is getting hte axel nut off
but all u have to do is use a jack on the breaker bar to break it lose
getting hte ball join u use this method to do it
https://honda-tech.com/zerothread?id=887859
its not worth paying others to do things that only takes 30min-1hr
Re: Honda charge alot for changing an axle? (komat)
Where is the full write up that one of the mods did on an axle change?
I remember seeing it with my old car when i heard a click from my axle, but than i sold it and forgot about it....
Please post it if you seen it.
And i head it would be less than $150 for Honda to do it? I am so desperate i would fork over 150....
I still may try it myself, so please post up that write up! thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">why not use the money that u were going to spend to install the axel on tools?
u only need couple</TD></TR></TABLE>
Holy shizzle...you have no idea how easy this is to do.
If you have no tools what-so-ever, and the dealer is going to charge you about 200 bills - you can surely get the required hand tools and jack for well under that, still come out ahead of the game AND have tools for the next job you need to do.
Seriously, it takes all of 20-30 mintues to change one....an hour if you've never done it.
The only 'special' tools I'd say you need are a 10lb mini-sledge (to whack the LCA off of the lower ball joint and along with a piece of wood, to knock the axle out of the hub), beefy flathead screwdriver (to pry the other axle end out of the tranny - NEVER pull on the axle, **** can become seperated inside of it), and a 32mm socket for the axle nut. Everything else is standard hand tools. You'll also need a catch pan to drain the tranny fluid into before you pull the axle out.
hey im in media near west chester, ill change ur axel for 90, if u supply the axel, i am a full time mechanic, but ibroke my leg 3 weeks ago on my r1, and totaled it. i think i can manage an axel change in about 20min.with hand tools
Re: (Ak2.5)
check my sig there good guys down at fsmoto ask for josh or dan tell them James from h-t sent ya there right on the border of PA-DE
Modified by g2crx at 5:18 PM 6/30/2005
Re: (g2crx)
at the dealership i work at we charge 1 hr labour to replace the axle. i would recommend you buy the axle else were so you save money there.
Re: (Jeezer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeezer »</TD></TR><TR><TD CLASS="quote">well firestone said they do mine for like 200.. so expect to pay 300-400 at honda</TD></TR></TABLE>
amen
amen
vickpick
Honda Civic (2001 - 2005)
03-13-2011 08:42 AM
James
11-10-2004 07:10 PM
