question on my 00 si headlights
on the outside where its plastic i assume its like permantly dirty or like faded or something. is there something i can do to make them look new?
Re: question on my 00 si headlights (underb00steg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underb00steg6 »</TD></TR><TR><TD CLASS="quote">sand paper 2000 grit.....something really fine </TD></TR></TABLE>
....works great....
....works great....
Farts in the shower
Re: question on my 00 si headlights (ian22)
Get some 1500 grit and 2000 grit wet sandpaper, some 3m rubbing compound and some plastix (by meguiars) and clean those headlights up.
Start with the 1500 and use plenty of water and rinse the sandpaper alot. Then when you feel the 1500 is good and done move on to the 2000 and repeat the process. After you get done rinse everything off very well and allow it to dry completely. After the headlights have dried apply some rubbing compound like you do wax and let it haze up then buff it out. Then apply the plastix the way you did the rubbing compound and whiola...new looking headlights.
Doing this will also reduce the pits in the headlights and take out any yellowish or cloudiness in the headlight.
Jap_Spec_Imports
11-16-2008 12:16 PM
