MY SPEEDOMETER IS NOT WORKING
HELLO I AM HAVEING A SMALL PROBLEM I JUST CHANGED OUT MY DASH ON MY EG AND PUT IN AN INTEG WITH AN OBD1 INTEGRA CLUSTER WITH THE OBD1 WIREING AND EVERY THING WORKS BUT MY SPEEDOMETER IT IS NOT THE GAUGE CLUSTER I TOOK THE ON OUT OF MY INTEG AND SAME PROB
CAN ANYONE HELP?
CAN ANYONE HELP?
Re: MY SPEEDOMETER IS NOT WORKING (GSR95DXHATCH92)
its your vehicle speed sensor. more than likely the connection has gone bad. check it out, its located on the top of the trans below the throttle body
Re: (peacexisxfree)
its one of 2 things..
1) you started the car, hit the gas while out of gear and the RPM moved, Gas needle went where it belonged, temp needle moved eventually... but speedo never went anywhere
2) the VSS is fuqued or connection is bad..
i hope its the ladder....
joethejoeman
01-18-2007 04:50 PM
