Need 'How-to" installing EK CLOCK
I just recieved through the mail my jdm ek amber clock.............Now how would you install it??? It has 4 wires coming from the back of it..............I was attempting to install it last night but just could not figure it out. I also searched the forums here and nothing came up.
Please help me out. I know this is possible to hook up.
Thanks
Thanks
Re: Need 'How-to" installing EK CLOCK (JDMCIVIC97)
If your clock comes with the wiring socket on the back, this will make the job easier. There is 4 wires feeding the clock, just look at the back side of the clock and you'll see where to hook it up.
Re: Need 'How-to" installing EK CLOCK (otilram)
You have four wires>
1-power after ignition
2-ground
3-constant power
4-dimmer
I know it wont help much, but thats the wires you need.
Adriano
2-ground
3-constant power
4-dimmer
Adriano
ok yes it came with the socket and plug but its been cut @ the 4 wires. Where do I tap into???? Where do I wire to get power????? There is red/black/yellow/white wires (4) Where do I tap into??????
Thanks
Thanks
Im not sure if this is correct but you could probably do it off of the radio.
Not sure maybe someone else will know?
Re: Need 'How-to" installing EK CLOCK (q45mm)
Try this.
red=power after ignition
black=ground
yellow=constant power
white=dimmer wire
Get 2 long wires (2-3 feet). Connect one to the black on the clock plug and connect is to the -/ground on the battery. Now connect the other wire to both yellow and red wires and lighty tap it on the +/power side of the battery and see if it works (it should though). If it work, just connect it to the radio wires.
Adriano
black=ground
white=dimmer wire
Adriano
Ok guys its not working - doesnt anyone have pics or a how to installing the EDM or JDM EK (96-98) digital clock ???????
I am so confused on how to make this thing work. How do I connect it? How do I wire it? Where do I wire to? and how?? and please show.
Thanks
Thanks
Re: (JDMCIVIC97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCIVIC97 »</TD></TR><TR><TD CLASS="quote">So the way to wire the EK Clock is to just match up the wires by color ????</TD></TR></TABLE>
Wires by color and functionon the harness are pretty much universal.
Found this thread finally and it worked. YOu dont color match the wires. That is totally incorrect.
Took pics of it too. I thought my clock lit up in amber but it didnt't because its UKDM spec (EDM)
Thanks anyways guys!
Link: https://honda-tech.com/zerothread?id=752789
GroundZer0
36
02-22-2006 12:12 PM
d16rice
20
03-09-2005 02:21 PM
nick.na
09-12-2003 03:52 PM
