white smoke coming out of valve cover breather??
whit/blueish smoke coming from valve cover breather? just put a turbo on last week? could it be bad rings? HG? what??
Re: white smoke coming out of valve cover breather?? (SteveoBA8)
did compression and leakdown test today. Compression was
cyl#1 80
cyl#2 175
cyl#3 70
cyl#4 60
so it cant be the head gasket, or all the cylinders would be low. right?? is there a way to pin point the problem without tearing motor apart?
cyl#1 80
cyl#2 175
cyl#3 70
cyl#4 60
Re: white smoke coming out of valve cover breather?? (96accordlxf22b2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96accordlxf22b2 »</TD></TR><TR><TD CLASS="quote">damn 175 is high no?</TD></TR></TABLE>
Depens. What engine are we talking about here?
Re: white smoke coming out of valve cover breather?? (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda owner »</TD></TR><TR><TD CLASS="quote">did compression and leakdown test today. Compression was
cyl#1 80
cyl#2 175
cyl#3 70
cyl#4 60
so it cant be the head gasket, or all the cylinders would be low. right?? is there a way to pin point the problem without tearing motor apart?</TD></TR></TABLE>
Broken ringlands buddy^^. Generally speaking, the ball park of 175psi is normal. 80, 70, and 60PSI is bad... bad... bad.
Let me guess, FMU for "fuel management??"
Modified by sohc_turd at 11:48 PM 2/21/2006
cyl#1 80
cyl#2 175
cyl#3 70
cyl#4 60
Re: (CustomX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CustomX »</TD></TR><TR><TD CLASS="quote">yea the white smoke is usually moisture in the motor </TD></TR></TABLE>
Actually, the white smoke is not moisture. The white smoke is the result of the charge escaping past the broken ringlands and pressurizing the crank case, and escaping out the breather. Thats my educated guess w/ nasty compression results like that.
Re: (sohc_turd)
in my other car... usually when it sits for a day or 2 it smokes for a little bit out of the breathers til it warms up... then afterwards its fine.. i always thought it was all the moisture from inside the motor from sitting athought i am talkin about a carburated v8
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std »</TD></TR><TR><TD CLASS="quote">
Depens. What engine are we talking about here?</TD></TR></TABLE>
b18c1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_turd »</TD></TR><TR><TD CLASS="quote">
Modified by sohc_turd at 11:48 PM 2/21/2006</TD></TR></TABLE>
b18c1
Re: white smoke coming out of valve cover breather?? (Honda owner)
so its for sure not bent valves? or a cracked sleeve? or a HG? also when i blow into cyl 3, i can feel the air come out of cyl 4, same with cyl 1&2
Re: (CustomX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CustomX »</TD></TR><TR><TD CLASS="quote">in my other car... usually when it sits for a day or 2 it smokes for a little bit out of the breathers til it warms up... then afterwards its fine.. i always thought it was all the moisture from inside the motor from sitting athought i am talkin about a carburated v8</TD></TR></TABLE>
You're correct in saying that white smoke almost always means moisture. However I highly doubt that your compression was that low either. I think the guy that said the ringlands said it best.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda owner »</TD></TR><TR><TD CLASS="quote">so its for sure not bent valves? or a cracked sleeve? or a HG? also when i blow into cyl 3, i can feel the air come out of cyl 4, same with cyl 1&2</TD></TR></TABLE>
Pull the head and take a look.
Can't fix whats wrong until you figure out what it is
EL TYPE R
01-20-2009 07:40 AM
Convert
14
03-04-2008 10:21 AM
