Quick release steering wheel? How to install? Need help!!
Hey anyone know where I could find a how to install tutorial of how to install the quick release steering wheel I already purchase the kit I just don't know how to install it anyone!
Re: Quick release steering wheel? How to install? Need help!! (kos99ngel)
What kit do you have, Give me pics/details and maybe I can walk you through it.
What car is this being installed on?
EDIT: Probably a JDM 92 DX Civic
Re: (zerovandez)
if you know how to remove the OEM steering wheel it's cake after that.
you then put the hub in place onto the column bolt it down with the large lug nut,
then bolt the 6 bolt from the quick release onto the hub. once thats done you need to find your center then bolt the other part of the quick release to the steering wheel.
its pretty self explanitory once you take the steering wheel off. the tricky part, which I dont know how to do, is make the horn button work. there's write ups on it. just do a search. but its not easy. what i did was put an alternate button on the dash bezel here's a pic of a set up with out the steering wheel.
Would I need to take anything out now that I have the steering wheel removed what about the airbag plug; bag do I take the whole airbag connection out
Re: (kos99ngel)
lol ya putting it all together is easy (done it) but can't get my horn to work lol i found the post before but never took the time to try it out....i'll try searching and post here.
Re: (kos99ngel)
Check out this place, doesn't explain how to wire it to a quick release but gives you a better idea.
http://importnut.net/civicsteeringswap.htm
Re: (Top-Fuel)
Okay thanks everyone for you’re help now I have this problem! Ummmmmm is there anything other hub that I could purchase like a short style because I don’t like how it came out I can’t reach my turn signal & the steering wheel its sticking out to much witch makes me put my seat back to much & then I can’t reach the pedals LOL I was looking around & this is what I found:
http://store.yahoo.com/twincam....html
Thank you
Thank you
you could use the smaller hub, i've never even heard of such a thing. If you remove the quick release you'll gain back the space. That shortened hub seems to be the only solution though.
Things you lose with aftermarket steering wheel: "easy" access to turn signals and wiper switch, horn, airbags, and signal cancellation.
Re: (Sijray21)
Alright thanks yeah I think I am going to order the Quick Release Short Hub
http://www.getnrg.com/nrgquickrelshorthub.php
Re: (kos99ngel)
I don't know why you would say that you lose all of those things, because with my Momo race wheel and hub, I have perfect access to the wipers/signals. Also, you can retain all functions, less the airbags, if you take the time to do it right. Someone already reference my write-up in my thread but I outline how to make the horn work as well as set up new buttons for cruise control. I've been driving with the momo in my civic for over three years, and the turn signal cancel, horn, and cruise control all still work perfectly.
-Alex S.
-Alex S.
Re: (97exd16)
anyone kno why the blinkers stay on after you turn after you installed a aftermarket wheel? But i recently put back my stock wheel and it still doesnt work, which piece am i missing?
is it this one?
is it this one?
Re: (djpeetur)
The big black thing is the wiring loom for the cruise, horn, and airbags. If you didn't take it off to put on your wheel, I'm confused. The turn signal cancel is the brass colored piece around the main shaft. The two little pegs that stick up line up with holes in the back of the factory wheel, and any aftermarket hub that was made for the car.
-Alex S.
-Alex S.
very confused about the blinker shut-off. here i made a write-up about it.
https://honda-tech.com/zerothread?id=1561283
ekhatchey
01-10-2008 06:15 AM
