oxygen sensor stuck old header old header not fit in car
I cursed out BauleyCivic and got banned
old header dont work anymore o2 sensor is stuck cant buy the tool cuh no running car suggestions list em
tried so far 7/8 open end wd 40
tred cresent wrench managed to round the ****** off
nearest autozone 20 miles nearest honda dealarship for new sensoer 40 miles no autoparts stores around no running car to drive 17 years old working on daily driver motorcycle doesnt run
Re: oxygen sensor stuck old header old header not fit in car (96accordlxf22b2)
bump have about 30 mins to fix tis bullshit
man i'm assuming english is your 10th language. use a 22mm wrench on the o2 senor. and fix your motorcylce
3 mintues now that i took the time to type it
type fast no vocablaury or personality so flame and ill walk to ur house and kill u
Re: oxygen sensor stuck old header old header not fit in car (Civicse)
no tengo un 22 mm wrench
rounded o2 sensor
heat with????? all i got is about a 30 ent lighter i dont have anything to heat it up unless its an oven lol
rounded o2 sensor
thnx for help anyways i really need this done
thnx ill go try that brb in about 10 minutes
heating it up now im going to try the vice grips
whts a channel lock?
nvm googled channel locks same thing as a slip-joint pliar right?
yep. or a device to lock channels on your tv, but the might no work
no im going to put on another one no axygen sensor is there a way i can tell the ecu there is a oxygen sensor with an ok signal?
MainStreamHonda
08-09-2011 09:36 AM
pli
41
02-27-2007 05:49 AM
