Do DIY rear camber with BOLT & WASHERs work?
I was wondering if any out there installed their own rear camber kit with bolts &
washers. If so do you see a difference of your tire wear from before and after you
had i on?
had i on?
Re: Do DIY rear camber with BOLT & WASHERs work? (Dub C)
It does work. It simply changes the geometry of the suspension. I didn't wait long enough to see if my tires showed camber wear, I put it on at first.
Re: Do DIY rear camber with BOLT & WASHERs work? (******)
Yeah it does work I lowered my eg coupe w/out a camber kit and wore out the inside of my toyo proxes within a few months then I got 3 washers and longer bolt and it seems to work great. I could tell a huge difference just by looking at it after I put them on. just make sure you put the washers between the car and the mount. I got the "Kit" myself for around $10 at Home Depot. Just take the old bolt in to find right size.
yeah it works just as good as the rear camber kits just not fully adjustable, my 92 hatch has eibach sportlines (1.6" drop) and 2washers took care of it.
