NO Speedo and NO VTEC, tried everything, HELP
I have a 94 civic ex with a b16a and my speedo just quit working and that caused vtec to quit also. i have replaced the vss and still nothing, have checked all my grounds...but my car runs to good to be the ecu its just no vtec so what could it be any suggestions would be nice.
Re: NO Speedo and NO VTEC, tried everything, HELP (Skunk.Werks)
i have been throwing a TPS code ever since i put the motor in last year and never had a problem until just recently, but im now throwing a MAP sensor code along with the TPS...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk.Werks »</TD></TR><TR><TD CLASS="quote">make sure you are throwing no codes. If you have a CEL, vtec will not activate.</TD></TR></TABLE>
um
his VSS not working is causing the lack of VTEC. and only certain CEL's will cause no vtec.
you need to start tracing wires and connectors to make sure everything is kosher in the wiring.
um
Re:
yah, sorry to but in and all but i have a similar problem and dont want to make another topic about no speedo, but i havent had a speedo since i bought my car like months ago. i have replaced to vss and nothing was considering getting a new cluster all together? thing is when i hit a bump of slap my speed sometimes it will work. any advice would be great, thanks in advance
Re: Re: (jdmpremonition)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmpremonition »</TD></TR><TR><TD CLASS="quote">both of you need to check your wires with an ampage meter.</TD></TR></TABLE>
close
ohmmeter.
close
ohmmeter.
Re: NO Speedo and NO VTEC, tried everything, HELP (cates_07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">um
his VSS not working is causing the lack of VTEC.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cates_07 »</TD></TR><TR><TD CLASS="quote">i have replaced the vss and still nothing</TD></TR></TABLE>
what do i need to check with the ohmeter, i tried my buddies cluster and that didnt work so i have no idea...
grammer nawzi
Have you checked your fuses under the dash? Sounds like you might have blown one of the 7.5amp fuses. Check to see if your alternator is working properly, if not, I will bet that you just blew a fuse under the dash.
Re: NO Speedo and NO VTEC, tried everything, HELP (sicky)
pull the plug off and make sure there is no corrosion in there, if there is, your not getting any signal.....
does your vss even work? did you replace it with another used vss? Test the vss that you have right now in another vehicle and go from there. Mine went out at one time, so I replaced it and had tried 2 bad used vss's and finaly got ahold of a new one from honda and it all works now. Good luck!!
Re: NO Speedo and NO VTEC, tried everything, HELP (sleeper98civic)
i had the same problem i just ended up running wires
one wire runs to the cluster and another runs to vss
i think its b10 from the ecu and it runs up under the dash and splits off to the vss and cluster THATS THE POSITIVE WIRE
AND FOR THE KID WHO HAS THE PROBLEM WITH THE TPS AND MAP SENSOR
IM JUST GUESSING SINCE ITS BEEN LIKE THAT SINCE THE SWAP .
TRY SWITCHING THE CONNETORS WITH THE TPS AND MAP BECAUSE THEY HAVE THE SAME CONNECTORS 3 PRUNG
civictype-r
03-15-2006 04:19 PM
ninety9ex
01-26-2004 07:40 PM
