94 gsr throwing 23 (knock sensor) and 43 (fuel supply...
No, my car doesnt run rich and i have no white smoke, so
what could be causing the code 43 for the fuel supply system??
it is also throwing acode 23 for the knock sensor, i have no clue
should i try changing my kncok sensor wires? everything seems
to be working correctly as far as vtec etc.
ANY HELP THAT CAN HELP ME SOLVE THIS PROBLEM
WOULD BE GREATLY APPRECIATED!! .
i don't think our civics had knock-sensors? not sure on that..i had a '94 GSR in my civic, but was told not to worry about the knock sensor CEL, even though i was putting in 94octane.
Re: (jdmpremonition)
im having a code 43 (fuel supply) problem too swapped O2 sensor and still there even after i reset the ecu... anyone know anything on this?
ok but how do i make the code go away? i read your other posts on the other thread and you just said resetting the ecu will clear up the fuel corrections and you also said that it something bad with the rom code?? so does that mean i cant make it go away?
terplaygroun_dc2
10-23-2008 09:38 AM
