EG civic W/H22 wiring by hasport need help!!
Alright, i replaced my block and i am having some trouble with idling... It will
1.) idle at 2.5k but drive fine
2.) idle at 1.5k and cut out at 2-2.5k when driving.
3.) not start at at all
I have three plugs that will reach the TPS, MAP and the sensor on the intake mani right next to the fuel rail that is the same plug as the other 2.
the 3 combo's are the three situations involving the 3 plugs when hooked up to the tps.
WHAT I AM ASKING FOR IS... if anyone who did this swap using hasport's wiring harness could tell me the color combos for the wires going to each sensor.
the wire colors i have are
1.) white/black, green/white, red/white
2.) green/white, red/blue, yellow/white
3.) yellow/red, green/white, solid white
thank you!!!!
thank you!!!!
Re: EG civic W/H22 wiring by hasport need help!! (alleyezonme)
The plug for the tps and map are the same just switch them around and fidn out which one is the corect one. If the map sensor does not work corectly your car should turn off.
Re: EG civic W/H22 wiring by hasport need help!! (DxTrix)
there are three sensors that share the same plug... i have been guessing for too long now, i need some proof!!
or if anyone knows an email address to hasport, that works too
well the way hasport wired up my **** i can reash all three plugs to the TPS. do you wanna see a pic.
Ok got one for you not trying to argue just helping out. This is your egr plug
After that I think you should be able to figure out which is the tps and what is the map sensor plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxTrix »</TD></TR><TR><TD CLASS="quote">After that I think you should be able to figure out which is the tps and what is the map sensor plug.</TD></TR></TABLE>
I won't say that
I won't say that
Re: EG civic W/H22 wiring by hasport need help!! (ICeDoUt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICeDoUt »</TD></TR><TR><TD CLASS="quote">
I won't say that </TD></TR></TABLE>
lol
lol
turboex
07-02-2002 11:53 AM
