ek b18c help
do u kno what mounts i need? do i need tranny mounts too? or will the stock d series tranny mounts work? im plannin to buy the 99-00 si mounts from my work which are about 200ish. thanks.
you would need a 99-00 SI rear L bracket and driver side motor mount bracket (bolts to the block with the 2 long studs)..the tranny side, a D or B series hydro mount will work...for vtec wireing all u need to do is run the wire from the vtec sol, and vtec psi switch to the ecu
99TurboBlue
07-09-2007 05:07 AM
SyDuck
01-28-2005 06:59 PM
