Fuse problem?
Fuse problem?
Ok i went to honk my horn today and i heard a pop, and my left turn signal cluster light lit up a little. My left headlight and turn signal are very dim on the outside and when i turn on my left blinker it blinks very fast but both lights ARE working just left side blinks really fast. And when i turn on my brights, the left turn light on the cluster gets brighter, but still blinks when i turn it on. I dont have the fuse panel cover so i need a picture of it so i can replace. Also if anyone knows anything else about it, like if it isnt just a fuse,maybe a relay, or a code jump in the computer, let me know. Thanks.
Also i found it only dims my left parking light and headlight when i actually turn the headlights on but when parking lights are on it seems fine. my blinker works normal and ticks normal but right when i switch my hadlights on its starts blinking faster.
BTW its on a 92 civic hatch.
Re: Fuse problem? (h22HatchEG)
check the ground on the harness. its on the inside under the hood driver side. its a little sqaure thing right by the engine mountcruise control unit. i had the same problem. good luck
are u sure its not a blown bulb, signal then check out side to see if it is cuz its usally if a bulb is burnt the side the blinks faster is the side that is burnt. it can be the realy also. go buy urself a haynes manule ill need it for everything
Re: Fuse problem? (MugenedEK)
I have a haynes and im very sure there isnt a blown bulb. I am almost posstive it is the ground, i noticed a little box hanging without a bolt. Thanks fmrprojects
Modified by h22HatchEG at 8:28 AM 2/22/2006
Ok my headlight works just fine. my dome light still dome light still does not work and niether does my horn button.
Anyone want to snap a pic of thier fuse panel cover for me so i can see a layout, or know of one online?
Mister_1
Honda Civic (2006 - 2015)
06-05-2018 05:36 PM
