what else needed to swap h22
so i finally decided to go with an h22 because it is cheaper than the gsr........i was wondering what axles I could use with it, and if I needed to change up the suspension becauseit is so much heavier?......if so, what should I use
Re: (eg6hamster)
i heard from a friend that the suspension will need to be changed to handle the weight of the h22.........is that true?........and can the axles that come in the complete changeover on hmotors online work with the civic hatch, 95'
Re: what else needed to swap h22 (msinsky14)
Hasport makes a kit thats called H2B if I'm not mistaken..allows you to use just about B-series everything except for the motor itself of course, maybe you should check that out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 »</TD></TR><TR><TD CLASS="quote">so i finally decided to go with an h22 because it is cheaper than the gsr........</TD></TR></TABLE>
thats a first...
thats a first...
