Need a quick confirmation
Sorry these questions must be annoying. but it should be a quick simple answer
Ok heres the set up. gsr bottom end with b16 head.
Timing belt. Matches the water pump 22 teeth. soo gsr timing belt right?
Headgasket- Not sure. I would assume for the block you are using... Someone confirm this?
Head studs- gonna go with arp. I would order for a gsr correct?
Also give me some l inks to these parts if you could
This will be my first time putting a block and head together. Kinda excited to see what happens
Re: Need a quick confirmation (fmrprojects)
ok that make sense. 1.8 with b16 head equals itr. (in a sense)
just wish it had the compression as one
