Greddy Ground Wire System
Re: Greddy Ground Wire System (bmiller17)
Step one unscrew.
Step two put new wire in place.
Step three screw
Add other grounding wires to designated areas and repeat.
I am making my own grounding kit later this week. 4 gauge wire and gold plated connectors.
Step three screw
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmiller17 »</TD></TR><TR><TD CLASS="quote">so basically just bolt up the rest of the wires anywhere that would make a good ground?</TD></TR></TABLE>
no you replace them with the existing ground wires, like trany ground ect.
now that i helped im going to say that they are useless and pointless sorry
Re: Greddy Ground Wire System (Slow_CvC99)
I wouldn't saying having everything grounded properly is completly useless, i did some research and it would probably be useless if you are looking for HP gains. BUt i did hear they work pretty well for improving gas mileage, stabalizing idle, better sounding audio. Not worth spending a lot of money, but definitly worth doing it yourself. Afterall, it is just wires.
i made my own wires out of 8 gauge, replaced the ones from the tranny, valve cover and the battery. i didnt notice any improvement in idle or gas milage.
Re: Greddy Ground Wire System (Green_Machine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Green_Machine »</TD></TR><TR><TD CLASS="quote">where did you get the gauge wires? is it the same kind of wires you use for amps?</TD></TR></TABLE>
should be...
should be...
Re: Greddy Ground Wire System (civicracr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicracr »</TD></TR><TR><TD CLASS="quote">i made my own wires out of 8 gauge, replaced the ones from the tranny, valve cover and the battery. i didnt notice any improvement in idle or gas milage. </TD></TR></TABLE>
Because you most likely didnt hook it up right. Just replacing them with bigger gauge wont make a good noticeable difference. You have to connect more ground wires than that, And they have to flow right. There's several diagrams for the kits out there, and it would be best to abide by those
Hooked up correctly you should notice a difference in low to mid range power, better sound through the speakers (slightly) along with a few other things like gas mileage etc.
Wazup
04-18-2011 04:04 PM
