solid check engine light
Im not sure on hondas.... havent fiddled with my motor too much yet.... but i just worked on a buddies car, and the CRANKSHAFT POSITION SENSOR was unplugged/bad, so check that cuz i had NO power to the coil from the ECU.... and NO power at the fuel pump plug.... so check that.... hope i helped
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockcivic103 »</TD></TR><TR><TD CLASS="quote">Im not sure on hondas.... havent fiddled with my motor too much yet.... but i just worked on a buddies car, and the CRANKSHAFT POSITION SENSOR was unplugged/bad, so check that cuz i had NO power to the coil from the ECU.... and NO power at the fuel pump plug.... so check that.... hope i helped
so that would cause my car not to spark and start? (the sensor)
i read the code and it gave me 10 short blinks and pause and 10 and etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockcivic103 »</TD></TR><TR><TD CLASS="quote">the crank position sensor controls the spark i guess.... so yea that would cause it to not start
if this works</TD></TR></TABLE>
that would cause it not to spark? are you sure?
cause i dont have one yet I was gunna jack it off my bros mani but i was waiting until it started first
if this works</TD></TR></TABLE>that would cause it not to spark? are you sure?
the crankshaft position sensor would cause the ECU to not send power to the coil, which in return would not make spark... there for, thats your problem with the no spark.... check to see if its plugged in, and if its plugged in, then try a different one..... hopefully i have been of some help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon »</TD></TR><TR><TD CLASS="quote">look at the ecu sticky on the top of the forum on how to check your codes and then count the blinks and tell us EXACTLY what is.</TD></TR></TABLE>
Help us, Help you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupraRXZ »</TD></TR><TR><TD CLASS="quote">
jack it off my bros </TD></TR></TABLE>
Jacking off your brother is in no way the solution to this problem
Help us, Help you.
