blew my motor, what are my options?
Location: The Real O.C. Oakland Chinatown, California, USA
1 Post
long story, short, i was driving home, heard clicking, thought it was my pulley/alternator belt, as i'm trying to get to the closest exit, i hear a crack, see metal fly out in my rear view mirror, and i end up with a hole in my block. the block was a sleeved 2.0L 9:1 compression with eagle rods. the head is a gsr. what i wanna know is, what could have caused this, and i'm sure i had enough oil. and i was driving normally when this all happened. and the motor was not acting up or nothing before this, it just happened out of no where. i also want to know if any of the parts are still good, and if my head is ok? the head is a gsr head. if it is ok, should i go ls/vtec or just get a gsr block, i'm looking for reliability because this is my daily driver. i also wanted to know what pistons can be used on the ls with ls rods, and no machine work.
pics:
Modified by candy eg at 7:21 PM 2/21/2006
Modified by candy eg at 7:17 AM 2/22/2006
pics:
Re: (Slopoke)
I dont know what you did. But man that is one big *** hole! When I threw a rod through my b18b the hole was nothing close to that size. If you are going to blow an engine, you did it up right.
Good luck finding the cause.
Re: (giff74)
its complete jealousy. it over herd you and your boys talking about a motor swap, got pissed, listened to an Eminem CD, and killed itself. sorry for you loss. bounce back even better
Re: blew my motor, what are my options? (candy eg)
its can probly be cause by detanation by runin too rich.was block u use? if its a b20 block there cylinder wall are thin. u should do ls/vtec
Re: blew my motor, what are my options? (MugenedEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenedEK »</TD></TR><TR><TD CLASS="quote">its can probly be cause by detanation by runin too rich.was block u use? if its a b20 block there cylinder wall are thin. u should do ls/vtec </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by candy eg »</TD></TR><TR><TD CLASS="quote"> the block was a sleeved 2.0L 9:1 compression with eagle rods. </TD></TR></TABLE>
Re: (Jmunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmunk »</TD></TR><TR><TD CLASS="quote">I bet the clicking noise was really a knock due to a spun bearing which ended up exiting the block.</TD></TR></TABLE>
detonation by running too rich caused this? sure about that one?
wow... no words for this one.
What does the oil look like? Milky white? Best bet would be to start taking it apart.
Re: blew my motor, what are my options? (fast88std)
possible oil pump failure.
i guess anything is possible, but i highly think not. Thats a good one though...
Re: (Jmunk)
or had a Bent Rod
or had a Bent Rod
Re: (djsire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire »</TD></TR><TR><TD CLASS="quote">haha too rich. i never opend up a motor and i know its too lean that causes detanation</TD></TR></TABLE>
I believe an overly rich rich condition can also lead to detonation.
Re: (sohc_turd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_turd »</TD></TR><TR><TD CLASS="quote">
I believe an overly rich rich condition can also lead to detonation. </TD></TR></TABLE>
no overly rich washes the oil off of the cylinder walls and kills the rings resulting in crazy blowby
Re: (Soccerking3000)
yes, depending on how rich that bitch is, it can cause serious misfiring and lead to excess blowby, but that was most likely lean, knocking like crazy and shimmied everything loose until it fell apart.
now you can buy my motor! i promise it wont do that!!
sux i was in same situatuion . evryone told me it was gone so i jus got new motor BUT i had a d16 back then in ur case tho would try to see if i could rebuild it with jus a new block hopefully
1 Post
well i was in the process of taking the head off today and when i took off the camshafts, i found out that they were arp head studs, and i don't have the socket to take em out so i gotta go get that and then continue.
1 Post
Re: blew my motor, what are my options? (GarageAlchemist)
o, and as for going back to sohc. thats a no go, im spoiled this was my first car, i started at the top, i cant go back down, i wouldn't be able to take it. if the head happens to be gone, i mite swap in a D, sell it, and get a 4x4 tacoma and lift it.
Drew96EJ
07-06-2004 11:31 AM
pssssst
12-03-2001 11:38 AM
