4x114 brake replacement question
alright guys i have a 93 dx hatch with the 96-97 itr brake conversion and im about to come up on needing new brake pads and maybe even rotors... the question is what brake pads should i buy??? from what ive heard the prelude 4x114 pads are to big to fit the itr calipers now i know accords are 4x114 also can these be used??? im a newby at this i know but i bet theres a lot of people out there who want to know the same thing... any help appreciated TIA
Re: 4x114 brake replacement question (macDelli)
ahhhhhhhhhh, the question that has been asked a billion times before.
i know a guy that can get oem replacement rotors for $400? in my opinion, that's a little too much. as far as pads go, i think GSR pads work fine.
Re: 4x114 brake replacement question (ADVAN EG2)
Any Integra pads work fine. Rotors is another story.
If you haven't done it yet, don't bother. The other Integra brakes are the same, and it saves you a ton of headache down the road.
search under my name.. i had that before and did the prelude 11" upgrade for cheap
If you want to keep the stock size rotors, you can jsut buy any 94-01 integra 4 lug rotors and have them redrilled to 4x114. Replacement pads are same integra. If you choose to redrill the rotors, you will also have to bore teh center of the rotor a few mm because the itr hub is a bit bigger.
Tuesdaynightfever
05-01-2008 04:58 PM
jayswift
Suspension & Brakes
10-20-2007 06:33 PM
