99-00 si owners> How do I get the door panel on the drivers door with the tweeter also??????
I had to remove the panel due to a window problem. Now it is fixed and i just want to put the panel on the drivers side back on. It almost seems inpossible to put the panel on the door without breaking something. The tweeter seems to be in the way. Is there some trick or something cause I know im not dumb, I just dont want to break anything thanks for all help.
Re: (r2d97)
You don't have to take the tweeter off (at least I didn't on my 97 EX). Just put the top front part of the door where the lip is on the panel into the window gap first. Do it behind the tweeter, so that just the top front part of the panel is in (panel will be at an angle sloping down towards the front), and slide the panel forward under the tweeter as you line up the rest of the panel into the window gap. This should do it, it has worked for me the five or six times I've taken the panel off. (if this is unclear I'll try to explain in more detail) Good luck.
AKA MoDeL FaWken JERKz
Re: (TophM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TophM »</TD></TR><TR><TD CLASS="quote">You don't have to take the tweeter off (at least I didn't on my 97 EX). Just put the top front part of the door where the lip is on the panel into the window gap first. Do it behind the tweeter, so that just the top front part of the panel is in (panel will be at an angle sloping down towards the front), and slide the panel forward under the tweeter as you line up the rest of the panel into the window gap. This should do it, it has worked for me the five or six times I've taken the panel off. (if this is unclear I'll try to explain in more detail) Good luck.</TD></TR></TABLE>
Re: (JDMmaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMmaster »</TD></TR><TR><TD CLASS="quote">It's also a LOT easier when you have the window all the way down.</TD></TR></TABLE>
Re: (SeaLevel)
yes, the little tweeter piece will pop off and pull out to give you a little bit of room to play. try doing this first. then just snap the tweeter piece back into place.
integracura
12-17-2007 02:06 PM
nihkiru
06-10-2007 01:33 AM
